Old 02-08-2011, 07:58 PM
nxm10 nxm10 is offline
Windows keep fogging up on my 2002 caravan
Here is a common example of what happens. We will pull the unfogged window van out of the garage, drive around for about 10 minutes or so it seems to vary and then it will decide that it is just going to start fogging up. Usually the two front side windows fog up first then the back side and back windows. I've tried blasting heat, turning the A/C on the defrost on (hot or cold, make no difference) rain-x antifog wipes, When it starts fogging up there's NO smell at all associated with it and i run it on FRESH AIR mode, not set in the recirculating air mode . The only thing that seems to start helping is if we open the windows, which is a pain since it is cold outside.
Old 02-08-2011, 08:23 PM
b1lk1 b1lk1 is offline
Re: Windows keep fogging up on my 2002 caravan
I would check for wet carpets, possibly one of the sliding door seals is leaking allowing water to get into the carpet which in turn freezes and when thawing it causes fogging. I know if I use the recirculation on my van, my windows fog up within minutes since my carpets are always wet from melting snow. Also, if there is any moisture and the van goes from a warm to cold zone, this will trigger fogging. If there is no antifreeze smell at all, this is the only logical explanation.
Old 02-08-2011, 08:59 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
When you switch from recirc to external air and back do you feel/hear air source shifting?
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
The Following User Says Thank You to RIP For This Useful Post:
b1lk1 (02-08-2011)
Old 02-08-2011, 09:20 PM
Of course, this could be the OTHER logical solution, lol.
Old 02-08-2011, 10:20 PM
brcidd's Avatar
brcidd brcidd is offline
Last car I had this complaint on was stuck in recirc mode---as stated- check for proper recirc door operation.
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 02-09-2011, 12:25 AM
If it is in fact stuck in recirculating mode and i dont feel or hear the air source shifting how do i check for proper recirculating door operation?
Old 02-09-2011, 07:39 AM
consultIII consultIII is offline
is your garage heated? Does this happen when the van is parked outside?
Old 02-09-2011, 09:36 AM
RIP's Avatar
RIP RIP is offline
AF -Advisor
This is a narrative from a service bulletin concerning a different problem but it has a good explanation on the system and also has the procedure you can do to test/calibrate your HVAC system. http://www.2carpros.com/questions/do...van-blend-door
If your test fails after repeated attempts meaning lights are flashing after completion post back here and I'll dig up the meaning.
Old 02-09-2011, 05:09 PM
plymouthsrock plymouthsrock is offline
Since the fresh air enters through the cowl, you could try putting a piece of paper over the cowl to check for suction with fan on high while switching mode from fresh to recirc. Or find where the recirc duct is inside the cabin and try it there.
Old 02-09-2011, 07:37 PM
brcidd's Avatar
Do you have climate control? with a digital temp setting? If so you can check for codes-- and see if you have a recirc door failure code-- it may have a broken recirc door hinge-- dodge and jeeps are known for that..
'99 GMC Yukon
Old 02-09-2011, 09:34 PM
Yea my van has 3 zone climate control but no digital temp setting. Is there any other way to check for codes?
Old 02-10-2011, 10:51 PM
Autotech3910 Autotech3910 is offline
Is your air-conditioning fully charged and functioning properly? When you set your climate control to defrost with heat on the a/c compressor should turn on. A properly functioning A/C system dramatically helps reduce moisture/humidity in the passenger compartment.
Old 02-11-2011, 12:31 AM
[quote=Autotech3910;6870089]Is your air-conditioning fully charged and functioning properly? When you set your climate control to defrost with heat on the a/c compressor should turn on. A properly functioning A/C system dramatically helps reduce moisture/humidity in the passenger compartment.[/quo
The air-conditioning is fully charged and works great it . When i turn the defrost with heat on i can hear the a/c compressor cycling on and off.
Old 02-11-2011, 12:44 AM
When i switch from recirc to external air and back i can not feel or hear any air source shifting.
Old 02-11-2011, 08:50 AM
brcidd's Avatar
Then it is time to pull the glove box out and have a look.....at the recirc door - see if you can see it through the recirc opening in behind the glove box..
'99 GMC Yukon
Help - Windows Keep Fogging In! gabstero Caravan | Voyager 5 02-17-2010 08:37 PM
2002 mountaineer rear power windows and wiper stops working juaniro Mountaineer 4 02-12-2010 07:22 AM
power windows stopped working - 2002 Mercury Mountaineer hoehring Mountaineer 2 01-18-2010 09:25 AM
Caravan keeps going into "anti theft" mode pfury1978 Caravan | Voyager 1 04-22-2009 12:39 AM
2002 Caravan chime caravanmom Caravan | Voyager 6 03-04-2009 01:46 PM
