Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 02-07-2011, 09:41 PM
carl80 carl80 is offline
2002 explorer 4.0l, will die when turning from stop sometimes
when im pulling out of the driveway, or trying to do a u-turn it will die, or try to and then lung a little when the rpm jumps up. any ideas? It has just over a 100k miles and i just replaced the spark plugs and fuel filter. (didnt help)
Old 02-07-2011, 10:20 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: 2002 explorer 4.0l, will die when turning from stop sometimes
What's the idle speed just sitting still with the transmission in drive and foot firmly on the brake? If you turn the steering with the vehicle sitting still in drive with your foot on the brake does it act like it wants to stall? How about when you get to one of the steering locks? Is the idle smooth or pretty rough?
If the idle is smooth but it tries to stall when turning the steering I'd suspect a problem with the Idle Air Control (IAC) since it is supposed to increase the idle air bypass under load. If the idle is rough anyway, then I'd suspect a vacuum leak. With the V6 it's probably either the PCV elbow or the intake manifold gaskets (common).
-Rod
Old 02-07-2011, 10:52 PM
I just went out and tried it. with it in drive the idle didn't change, but then i put it in reverse the idle dropped then picked back up. then couldn't get it to do it again. talking to the wife (her car) that is when it happends most of the time. and if turning in a parking lot from a stop and changes gears, it might die.
Old 02-08-2011, 07:37 AM
shorod's Avatar
SHO No Mo
So was the idle smooth or rough (could feel the engine running in the seat)?
-Rod
Old 02-08-2011, 10:32 AM
its not 100% smooth. you can feel a little miss fire.
Old 02-08-2011, 01:34 PM
shorod's Avatar
SHO No Mo
Does your 2002 have spark plug wires or Coil on Plug (CoP) ignition? If plug wires, you should consider replacing them as well.
I'm betting though that you have a vacuum leak causing the concerns, as mentioned in post #2 above.
-Rod
2002 explorer random steering vibration/shudder when turning from stop johnsonsmith1234 Explorer | Explorer Sport Trac 2 09-26-2010 01:12 PM
2002 explorer v8 4wd eb high idle and shifting problem BAKERCONTAINER Explorer | Explorer Sport Trac 0 02-03-2010 02:22 PM
2000 Explorer noise/vibration when turning from a stop robbarry Explorer | Explorer Sport Trac 8 03-07-2008 12:55 AM
2002 Explorer 4.0L cranks, but won't start rogval Explorer | Explorer Sport Trac 2 06-22-2005 11:01 PM
Explorer XLT 94' When turning from stop rear makes grinding noise krid002 Explorer | Explorer Sport Trac 2 04-26-2004 05:50 PM
