Go Back   Automotive Forums Car Chat > Mercury > Villager
Old 02-07-2011, 03:59 PM
NJICEMAN NJICEMAN is offline
1997 villager will not start
1997 villager will not start. Cranks fine. I checked for spark on the #1 wire, did not see a spark, also checked for a spark from the coil wire, nothing. Then I removed the distributor cap, all looks well, but i noticed that the rotor did not spin when I tried to crank the engine. Any ideas?
Old 02-07-2011, 05:41 PM
tempfixit tempfixit is offline
Re: 1997 villager will not start
Welcome NJICEMAN;
How many miles on vehicle??
If the rotor is not turning then the timing belt has probably broken. Did the engine stop running all of a sudden while driving or idling. These engines are NON-INTERFERENCE engines so if someone tells you that the engine has bent valves or such they do not know what they are speaking of. That does not happen on these engines.
If you are mechanically inclined it is not a hard job to replace just time consuming. Took me 8 to 9 hours to do mine. Including replacing water pump. You may want to replace water pump and thermostat ( Use a Nissan or Ford thermostat, too may problems with atermarket thermostats)at the same time.
On the top of the Villager Page there is a link for a Online Service Manual:
Any questions don't hesitate ton ask.
Old 02-09-2011, 07:21 PM
Have you determined if the belt is broken?
