Old 02-07-2011, 04:11 AM
KevHw's Avatar
KevHw KevHw is offline
Mercedes SL63 - double build
Hello everyone.
It feels like it's been a long time since I managed to last build anything. I have a few half-started kits laying around but decided to create this thread to help keep me motivated and share my progress.
I have both types of the SL63 and also bought a set of Hobby Designs PE detail-up set. I'm planning on building one pretty much straight OOB and the other using the PE set, slightly "tuned".
Started work on the brakes. Stock brake disks:
PE brakes are very nice with individual pins supplied for what I think are the retaining clips. They are a nightmare to work with though. So I shaved off the stock clips from the plastic part:
Applied to PE brake:
Comparison:
Took inspiration from Macio4ever's NSX build to separate the floor from the interior tub. Filled the hole with 1mm styrene sheet:
Seat mount removed for easier painting/detailing/flocking:
Locator hole drilled so the tub is in the right position:
After seeing ZoomZoomMX-5's hint about the seats, I half opened the joint and bent it back:
Stock on left, modified on right:
Thought I'd only modify the driver's side seat. I had to slightly re-shape the driver figure to fit into the seat better. Legs have been straightened but the back reclined has not been shown:
Did some slight work on the engine. I noticed there is a gap between the engine block and the front pulley-face:
Filled in with some 0.5mm styrene for added support:
That's as far as I've got so far. Let me know what you think.
Thanks!
Old 02-07-2011, 05:22 PM
da_ashman's Avatar
Re: Mercedes SL63 - double build
Nice builds!!
Old 02-07-2011, 08:42 PM
MidMazar's Avatar
MidMazar MidMazar is offline
Cool i still want one of these. I love the brabus wheels. Keep us posted.
In Progress
Old 02-11-2011, 10:46 AM
kans0002's Avatar
kans0002 kans0002 is offline
i like that driver figure...where did you get him?
