Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '91 - '96
Old 02-06-2011, 04:32 PM
Stumped01 Stumped01 is offline
Question 96 Jetta ...Starting Problems
I believe many owners have this similar problem..has anyone found a dependable solution.
My Jetta won't start ..usually in wetter conditions..even if the car itself is under a shelter or covered roof... it'll crank...and have to as many as 3-5 times...with intervals in between..before it finally starts..n then idle becomes a challenge..until it warms up... usually the engine dying a couple of times..in between the idle..
I believe..many know what I am talking about..n sometimes..at lower speeds driving..the engine stalls for a spurt...
Please advise..if anyone has come up with some solid ideas...cheers n thanks...
Old 04-25-2011, 08:25 PM
RadicallyLowly RadicallyLowly is offline
Re: 96 Jetta ...Starting Problems
did you check the Coil...according to specs.
1998 VW Jetta starting problems Carcarius '97 - '03 33 12-11-2013 06:27 AM
96 Skylark starting problem mlb55 Skylark 0 03-14-2009 12:13 PM
95' jetta starting problems Mattsjetta '91 - '96 3 05-26-2006 03:31 PM
Help!!! 87 Jetta Starting Problems gearshiftVW '83 - '90 5 09-14-2004 08:42 PM
91 Jetta Starting Problems -HELP!!!! tivaclare '91 - '96 3 08-03-2004 08:00 PM
