Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 02-06-2011, 11:48 AM
MYTBIRD50HO's Avatar
MYTBIRD50HO MYTBIRD50HO is offline
Silver Bullitt00
2003 Ford Explorer Steering problems
My truck just recently started to act up when steering the truck in both directions. It will get tight then loose then tight then loose as you turn the wheel. Any ideas on what the problem could be? Thanks for any info
Old 02-14-2011, 11:24 AM
bigryry bigryry is offline
Re: 2003 Ford Explorer Steering problems
I have been having similiar issues. I took it in and was told all 4 ball joints, and 1 tie rod end was shot. Explorer ball joints cannot be greased so they go often.
Something to look into
Old 02-17-2011, 03:20 PM
Silver Bullitt00
I do have a torn tie rod end boot which I know about for a while now. Maybe thats the prob. Thanks
2000 MUSTANG GT 5 SPD TO MANY MODS
2003 FORD EXPLORER XLT V8 K&N
1996 TOYOTA CAMRY 2.2 I4
Old 02-17-2011, 04:24 PM
skeeter123 skeeter123 is offline
Definitely not my area of expertise, but I think that the steering column has something like a U-joint in it, after it comes thru the firewall and before it goes to the steering rack. Maybe that joint is catching/grabbing as you rotate the steering column. So, does it get hard to turn at the same point in each rotation of the wheel?
FWIW.
2003 ford explorer cracked rear hatch fmrmarine Explorer | Explorer Sport Trac 82 12-01-2009 05:44 PM
2003 ford explorer cracked rear hatch fmrmarine Explorer | Explorer Sport Trac 3 12-23-2005 03:33 PM
2003 Ford Explorer KeyPad Code?? jimmerjr Explorer | Explorer Sport Trac 5 01-09-2005 05:30 PM
