Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 02-05-2011, 01:05 PM
mekats mekats is offline
blend door motor
heater doesnt work no matters what you put it on it is ice cold ...dealer said its the blend door motor and it will cost around 900.00 to fix . does anyone know how to get it out so it can be replaced ...i find the part for 60.00. Its a 2005 grand marquis with only 50,000 miles and the heater has been out for about a year
Old 02-05-2011, 02:29 PM
Blue)(Fusion's Avatar
Blue)(Fusion Blue)(Fusion is offline
Send a message via AIM to Blue)(Fusion Send a message via Yahoo to Blue)(Fusion
Re: blend door motor
I believe you just have to remove the glove box door to access the blend door. I am not sure though. Even if you have to pull the dashboard off of the firewall (I am 99% sure this is not necessary), save yourself $800+ and do it yourself.
http://p71interceptor.com/heatercore/replace/pictures/
2000 Mercury Grand Marquis LS
- 119k / 14.89s @ 92.11MPH [ pictures | videos ]
> Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok
> Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB
> BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms
> CVPI aluminum driveshaft
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
