Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Avalanche
Old 02-04-2011, 10:54 PM
VenturaFwy VenturaFwy is offline
Question Avalanche Trailer Hitch
Does anyone know if the trailer hitch that comes on the 2011 Avalanche with the heavy duty trailering pkg is a Class IV weight-distributing type hitch?
Thanx.
Old 02-06-2011, 06:44 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Avalanche Trailer Hitch
Thanx.
Check with your GM dealer and sales department.
Your GM parts man can run you vin no and find out what parts they have on them.
MT
Old 02-06-2011, 10:46 AM
Thanks, MT. I am considering purchasing an Avalanche. I don't have one now. I asked the dealer (via email) the exact question I posted here and his reply was "Yes, it has a trailer hitch". That was why I was hoping someone who already owns one might know the answer. I have seen several Avalanches in parking lots, etc., and they look like they all have the same kind of hitch but it is hard to tell by looking if it is a Class IV. Maybe I will try some more research at GM.
Old 02-06-2011, 11:57 AM
MT-2500's Avatar
AF - Advisor
Catch ones of them dealer salesman and pin him down on it and if you are ready to but get it in all in righting.
You should be able to buy it the way you want it.
Trailer hitches are probably or can be put on/installer by the dealer after they get them.
Good luck
MT
Old 02-09-2011, 11:02 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Question to you is...what kind of weight are you planning on towing? GVWR is 7,200 lbs and GCWR is 11,000 lbs., and rated at 8,100 lbs towing capacity...8,000 for AWD (according to official GM website http://www.chevrolet.com/avalanche/).
Unless you are towing above ~5,000 lbs, you shouldn't have to worry about stability that the distrbuted hitch would provide. But according to the fine print on their trailering poster: http://www.chevrolet.com/assets/pdf/...ringPoster.pdf
it states that a weight-dstributing hitch and sway control is required over 5,000 lbs, implying that the hitch that comes on it is not such.
[EDIT] However, to use logic, in order to tow what the truck is rated for it would have to be a Class IV hitch which by most standards are weight-distributing. It may just not come with the additional hardware needed to use a WD hookup.
Hope this helps!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
2004 2 wd without the trailer hitch How do you install the trailer light harness? bmanflyer Silverado 6 04-27-2007 07:49 AM
FS: Two Reese and Hidden hitch trailer hitchs new in box husky62 Caravan | Voyager 0 03-25-2007 07:14 PM
trailer hitch for sale Stans Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 2 06-05-2004 10:10 PM
Hidden-Hitch Trailer Hitches boodie Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 2 10-30-2003 12:35 PM
OT: What not to do with a trailer hitch hobbes69 Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 7 05-09-2002 07:50 AM
Tags
avalanche , hitch , trailer
