Old 02-04-2011, 11:47 PM
kelshm kelshm is offline
Steering issues
I have the '89 Cherokee Laredo 4x4. The steering seems to be extremely loose and will also wander on the highway. I had it in today for a front end inspection and they told me that everything was tight, no bad bushings, etc. The only thing they could find was tire pressure a bit low...and yes it was and yes it helped some but has not resolved the issue. It still wanders and there is about 4-6 inches of play in the steering wheel. Any ideas?
Just FYI, to the many people with starting issues....If my Jeep won't start (turns over but no fire) I will jiggle the wiring to the computer (above the accelerator pedal) and the problem is gone for awhile. I've tried making a better connection there but it doesn't help. I just have to do this every now and then so not too concerned but hope that this helps somebody.
Old 02-04-2011, 11:49 PM
Re: Steering issues
I might also mention that the steering box is new and also repeat that none of the steering components (tie rod ends, bushings etc) have any play in them. Many have been replaced in the last year to tackle this problem...all helped but the problem is still there.
Old 02-04-2011, 11:53 PM
Re: Steering issues
LOL....OK...one other thing...the tires on the Jeep are new BF Goodrich's. They definitely made a huge difference in the drive-ability but the problem was there before I had them installed.
I also notice that when stopping it will pull to one side or the other, not necessarily the same direction 2 times in a row. This is not severe but I'm sure it could be related.
Old 02-05-2011, 09:58 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: Steering issues
I'd check the wheel bearings; if everything else is tight, that's where your play is likely to be happening.
Did the mechanic also check all the bushings that hold your axle in place? Those can wear over time also and contribute to "the slop".
I imagine with an '89 you have plenty of miles on....
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 02-05-2011, 11:59 PM
Re: Steering issues
I'll check the wheel bearings tomorrow. The bushings are all new in the past year...and they were BAD before.....really bad. I'll let you know what I find.
Old 02-06-2011, 01:12 PM
LittleHoov's Avatar
LittleHoov LittleHoov is offline
Send a message via AIM to LittleHoov
Re: Steering issues
If you havent already, check out the track-bar. Its the metal bar that runs from the passenger side of the front axle up to the driver-side frame.
It normally fails at the frame side, youll want to check for any up and down movement, mine was shot and had a lot of wandering like you describe.
The bolt at the passenger side can get, sort of wallowed out too, but thats not quite as common.
If your 89 is still on the original trackbar, it might be about time.
2000 Oldsmobile Intrigue 3.5 DOHC V6
Mods: Fenderwell Intake, High-Flow cat, U-bend delete, 12-inch front rotors, GMPP handling kit, 20% tint, Pioneer front and rear speakers, Eclipse HU, cleared corners
1986 Jeep Cherokee 2.8 V6
Old 02-07-2011, 09:06 PM
Re: Steering issues
Checked and there is no wheel bearing play. The track bar is about 6 months old. I may just have to take it to a different shop that has a better track record than this shop. Of course I didn't KNOW they had a bad track record until after I took it to them.
Up next....rear main seal!
Steering/Alignment Issue Silvio99 Tahoe 1 01-03-2011 08:39 AM
steering seems hard, possible power steering issue? XGamesJ6 Cutlass Series 0 06-19-2006 09:10 PM
Steering Issues w/ Avalon vesnyder Avalon/Pronard 15 08-01-2005 08:23 PM
Need Help-Steering issue twistedone Accord/TSX/Accord Hybrid 3 11-21-2002 01:51 AM
Steering issues with 320d Touring Phil123 3 Series 1 08-31-2002 07:15 PM
