Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 02-04-2011, 11:15 AM
ProfessorRiffs ProfessorRiffs is offline
Electrical problems with a 96 Explorer XLT
Just bought this car, and after a couple of days the electrics started going wacky. When I turn the car off, the lights on the lower corner of the inside of both front doors stay lit. Everything electric works even with the keys out of the ignition.
I dis- and re-connected the battery and the problem is still there.
Any suggestions? Thanks a ton.
Old 02-04-2011, 01:03 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Electrical problems with a 96 Explorer XLT
Welcome to the forum, fellow Cedar Rapidian!
It's pretty common for the door pin switches to fail on this vintage of Ford. Unfortunately the switches are located in the door latches with makes this a bit more difficult to confirm. Often some electrical parts cleaner will provide a pretty long term fix without replacing the physical switches.
Do the dome lights come on when the door is opened and go off when the door is closed, or do they function similarly to the door lights?
-Rod
Old 02-04-2011, 01:07 PM
Well hello from CR!
With the exception of the light on the door staying on, everything functions properly. But, it also functions properly without the keys in the ignition.
Thanks for the quick reply!
