Old 02-03-2011, 06:59 PM
lilredracer lilredracer is offline
major swap!
I would like put a 3.2 SHO into a 1990 ford probe GL. I would like to know if anyone can tell me what to expect. maybe help me identify future obstacles and give advice on what to or how to mod components in order to overcome and complete my goal.
thx.
lilredracer
Old 02-04-2011, 12:37 AM
oldblu65's Avatar
oldblu65 oldblu65 is offline
Re: major swap!
First of all , you'll have to severely modify the engine compartment for the 3.2 SHO engine to even fit into the space ! You'll have to utilize the entire drivetrain from the Taurus as your present drivetrain will not fit the 3.2 engine . The engine ( and transmission ) wiring harness from the SHO will be needed to have the engine and transmission properly operate . The original Probe wiring harness will have to be intergrated with the engine harness . I think the new engine and drivetrain will prove to be too wide for the Probe body and custom drive axles will be needed unless you want the wheels to extend beyond the fenders ? And the list goes on ....! It can be done if you have the finances , experience , and needed tools to accomplish the major task you're talking about ! You could have a professional do the job if your wallet is big enough ? Good luck and keep us updated !
" Sometimes I grow so tired "
Old 02-04-2011, 06:45 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: major swap!
Since in 1990 the 3.0L V6 was available in the Probe, I'm not sure that there'd be a lot of difficulty fitting the 3.2L in the bay, but there still would be a lot of fabrication required with the drivetrain and powertrain management. You certainly wouldn't want to tackle such a project with the idea you'll get your money back out of it. At least not if you do the swap safely and correctly.
-Rod
swapping 91 wrangler 4.0 for 97 cherokee 4.0 - fuel lines mismatch rykowalspt Wrangler 1 03-26-2009 05:07 PM
h23 swap 4th gen civic? 92lude91dx '88 - '91 Civic | CRX | Wagon | Shuttlee 4 03-16-2009 11:43 AM
350 motor swap bowtieballs2000 Performance 0 03-09-2009 10:26 PM
97 Jimmy engine swap gsnats Problem Diagnosis 5 03-06-2009 09:40 PM
Nissan Quest V6 to 2.4 ltr 4 cylinder swap Scraped Knuckles Quest | Presage | Serena 4 02-20-2009 08:59 AM
