Old 02-03-2011, 11:18 AM
PapaC1 PapaC1 is offline
03 caravan sport over heating/no heat after puddle
Does anyone know what a "sailboat light symbol" on the dash means. 03 dodge caravan sport it's over heating and no heat. my daughter went thru a good size puddle yesterday. wondering if a fuse or relay blew
any help would be appreciated
Old 02-03-2011, 11:34 AM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: 03 caravan sport over heating/no heat after puddle
Remove the radiator cap and make sure the radiator is full. Make sure the coolant in the coolant bottle is within the marks. Make sure the serpentine drive belt is in place. They regularly come off driving through puddles. The radiator cooling fans may not be turning on. Turn on the A/C and they should turn on in seconds. Turn the A/C off then let the van idle and heat up. Fans should come back on within 10 minutes. If the fans are good you may need a new thermostat. Sailboat???
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
The Following User Says Thank You to RIP For This Useful Post:
PapaC1 (02-13-2011)
Old 02-13-2011, 09:29 AM
Thanks for the help. It ended up being a rubber hose under the right side under passenger front flont floor that went to the rear heat. was sliced by ice when she went thru a large puddle with chunks of ice'
Thanks again
Old 02-13-2011, 09:31 AM
oh ya that so called looking Saiboat light turned out to be the overheating light.
boy she takes after mommy LOL
Old 02-13-2011, 10:38 AM
cbwilsha cbwilsha is offline
Don't be too hard on her. I just looked in the Owners Manual (Page 5) and the overheating symbol DOES look kinda like a single masted sailboat.
C.B.
Old 02-13-2011, 10:59 AM
Alphabravo Alphabravo is offline
It's supposed to look like a thermometer dipped in water, but it does look like a sailboat
