Old 02-03-2011, 07:21 AM
rprough's Avatar
rprough rprough is offline
Sensor location on 1993 Sonoma
I have a 93 Sonoma, 4.3 vinZ. Where is the coolant temp sender at? I have a non functioning temp gage on the dash (non digital). I replaced the sensor next to the thermostat housing (2 wire) that was in the water jacket, no change, but someone told me it was on the passenger side of the engine block (1 wire). If it is ideed on the side of the block, what sensor did I actually replace???
Old 02-03-2011, 07:50 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Sensor location on 1993 Sonoma
The One by the thermostat is for the computer tempt reading.
Look on the side of cylinder head for a sending unit for dash tempt gauge.
Let us know what you find there.
MT
Old 02-03-2011, 07:21 PM
rprough's Avatar
I did indeed find the temp sensor on the passenger side of the engine. It is 1 wire. I will change it this weekend. It has 12 volts going to it. This is normal I assume? I was thinking about grounding the wire to see if it makes the gage move. Is this a good idea? Luckily I work at the local GM dealership and can hit the mechanics up for answers.
Old 02-04-2011, 08:34 AM
MT-2500's Avatar
AF - Advisor
NO. No. No.
It is never a good ide to direct ground a 12 volt power supply.
To test for gauge movement I use a ground threw a old type bulb test light and only long enought to see if gauge moves.
Let us know how it goes.
MT
Old 02-10-2011, 07:14 PM
rprough's Avatar
Actually I havent been able to change or do anything yet. The 2 wire sensor the dealer has says can be used as a 1 wire sensor. Does this make sense? Its really hard in the winter when you dont have a garage to work in.
So the reason to use a bulb is to provide a load I assume?
Old 02-11-2011, 07:42 AM
MT-2500's Avatar
AF - Advisor
No way.
One wire and 2 wire sensors are all different.
Switching them might even destroy PCM.
Tell that dealer he is full of it.
MT
Old 02-11-2011, 09:29 AM
rprough's Avatar
Dont know what to do then. Cant seem to find a 1 wire sensor anywhere. Local parts stores, dealer, online, anywhere. If I cant then 1 option would be to mount an aftermarket coolant gage, but I prefer to keep it all stock looking. Any ideas where to get one? I am replacing the coolant sensor that is located on the right side of engine. Does this one still go through the PCM and not straight to the instrument cluster? I know the one next to the thermostat housing does, hence the 5 volts there. Not like the 12 volts on the side of the head.
Shure would appreciate any help you might give here.
Old 02-11-2011, 10:32 AM
MT-2500's Avatar
AF - Advisor
First step is to test dash gauge as outlined in upper post.
If it is working.
Them find another GM parts dealer and give him your vin no and tell him you want the one wire tempt sensor for the dask gauge.
Or check your local parts places for one.
Good Luck and let us know how it goes.
MT
Old 02-11-2011, 07:18 PM
rprough's Avatar
Hoping its just the sensor because all the other gauges and even the lights work on the instrument cluster. Ill post when I get it checked.
Old 02-12-2011, 07:43 AM
MT-2500's Avatar
AF - Advisor
A few minutes with.
A LITTLE PROPER TESTING WILL TELL.
Or you can just throw parts at it and hope for a fix.
Good luck
MT
Old 03-20-2011, 07:01 AM
rprough's Avatar
I finally fixed my dash temp gauge with a new sender and it works great. Also replaced the remote oil filter line from block to filter mount. New plugs are on tap also along with a relay rod and inner and outer tie rods on 1 side so I can get it lined up. Also need to replace 1 of the torsion bar mounts under the crossmember to fix trim height. Think Ill do the torsion bar mount first before getting it lined up though.
Old 05-25-2011, 10:52 PM
rprough's Avatar
Finally got all the stuff fixed as stated in my last post.
Old 06-22-2013, 06:47 PM
markp markp is offline
I have the same truck and cannot find a single wire temp sender. Do you happen to have the part # you used to fix yours?
My email is: [email protected]
Old 06-22-2013, 07:09 PM
MT-2500's Avatar
AF - Advisor
Look on side of cylinder head.
Your local parts place should have a listing on tempt sensor for gauge.
MT
Old 07-03-2013, 04:29 PM
I found the part at AutoZone. It is part # TU174 and was the single wire sensor.
