Old 02-01-2011, 06:11 PM
thetenfold thetenfold is offline
Arrow 1998 Rear Defrost Doesn't Work
My rear defrost does not work in my Ford Escort SE Wagon.
I press the button and it lights up, but doesn't work.
I can hear the relay click after I press the button.
The fuse is good, but I'm not getting any power to the grid.
What should I do now?
Old 02-01-2011, 08:44 PM
consultIII consultIII is offline
Re: 1998 Rear Defrost Doesn't Work
When you say your not getting power to the grid; does that mean you checked the connector at the grid for voltage?
If you have no power at the connector but hear the relay click; check for power out of the relay.
If there is voltage at the grid connector you may have broken grid lines.
Post back which is the case.
Old 02-02-2011, 09:14 PM
Yeah. Then for shits I checked all the grid lines across and nothing.
So, trace it from the relay to connector? I wish I could find a diagram showing exactly where it runs.
Tags
defrost , escort , ford , fuse , rear
