Old 02-01-2011, 03:43 PM
jstride jstride is offline
2001 coolant leak
wifes van just started lossing coolant, can see underneath put cant see where its coming from . possibilites? thanks
Old 02-01-2011, 04:09 PM
tempfixit tempfixit is offline
Re: 2001 coolant leak
what year,
what engine
drive it up on car ramps to look.
which side of engine is leak, front-- back??
need more info.
Old 02-01-2011, 04:17 PM
2001 winstar 3.8 l leaking somewhere on right side
Old 02-01-2011, 04:23 PM
Percon Percon is offline
Check radiator hose, water pump.
Old 02-01-2011, 05:15 PM
Scrapper Scrapper is offline
AF Premium User
hope not head gasket is it missing? and keep going on checking the above.
Old 02-02-2011, 01:23 PM
just checked fluid down just a little but there is some foaming action going on. and i can smell coolant inside slightly but no wet spots.im scared this is not good
Old 02-02-2011, 01:55 PM
by the way its about 0 wind chill out in tx so no i am not working on i!
Old 02-02-2011, 07:21 PM
wiswind wiswind is offline
Most likely not caused by the head gasket.....1995 model year had issues with the head gasket, all other years are MUCH more reliable in that regard.
They made changes that seem to have corrected the problem.
On the right (passenger) side, several hoses, front cover (aka timing cover) gasket, cross over tube and water pump are possible causes.
Also, lower intake manifold gaskets can leak like this.
Of course, ALL these things are not bad (just typing the list makes me nervous)......only 1 is going to be causing the leak.
It can be quite difficult for the pro's to determine what is leaking.....much less us DIY folks.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
Old 02-03-2011, 01:25 PM
yes i know! motor position and cramped quarters makes it really tough!
'94 3800TS: power steering and coolant leaks jarl Trans Sport 1 08-03-2010 04:02 PM
2001 Deville coolant leak - danger? MerNion Deville 4 03-17-2010 09:14 PM
'94 TS 3800: HUGE coolant leak - and other fluids jarl Trans Sport 23 10-31-2009 07:53 AM
2001 Chevy Cavalier Coolant System Problem getwilde Cavalier Problem Diagnosis 0 09-18-2009 06:43 PM
98 Grand Caravan 3.3L Coolant Leak hooperkj Caravan | Voyager 4 04-22-2009 04:17 PM
