Go Back   Automotive Forums Car Chat > Nissan > Altima
Old 02-01-2011, 02:44 PM
tonyull tonyull is offline
05 altima code p1122
05 Nissan Altima 2.5
Was recently in a flood and got about 1 foot of water in passanger compartment, after cleaning and drying and checking to make sure no water was in vital fluids in or on ecm or ipdm or fuse and relay panels, I strarted the vehicle it idles fine. with no MIL but had no Accelorator. first assumption TPS was under water and no good. (wow on Nissan you cant get just the TPS) so I replaced the electronic throttle control actuator and while in the learning process the MIL came on. scan tool says its a p1122 electronic throttle control actuator (I know its posable to got a bad part new) tested actuator apears to work like a potentiamiter assume part is good, find nissan FRMs and make all the checks that it suggest from rechecking all grounds and connections to voltage checks on ipdm connectors put car back together run threw throttle learning system and get the 5 slow flash with no MIL take a couple days off to think about it go out this am, Mil is on scan tool says p1122 again try the learn process all over and no go reset errors run car for 20 min to bring to temp and retry mil comes with p1122 if I try to retreive codes with out scan tool just get 5 slow flash. any ideas anyone?? My wife would really like her car back, and I would like to beable to get away from gas powered vehicles and back to working on Diesel
Need help programming key 2006 Altima educatedk9 Altima 1 07-27-2010 09:34 PM
96 Altima : Trouble Starting After Head Gasket Replacement EliteDistance Altima 15 05-31-2010 04:56 AM
This altima looks tight Zainiboy Altima 2 04-18-2009 03:08 PM
97 Altima Code P0505 x1gary Altima 0 11-01-2007 09:08 PM
97 nissan altima code P0171 mingo Altima 3 05-28-2007 09:39 PM
