Go Back   Automotive Forums Car Chat > Toyota > Avalon/Pronard
Old 02-01-2011, 11:34 AM
word2yall word2yall is offline
Fluid leaking
Now please read the post fully, before you respond telling me the leak is Anti Freeze
Today I noticed a bright neon green fluid leaking under my car, as you did, I automatically assumed anti freeze. As there is 8 inches of snow on the ground, I didn't go under to locate the leak, but rather figured I would top it off and wait for good weather. Upon grabbing my anti freeze jug, and poping the hood, I realized, I have used nothing but the red colored anti freeze for the past few years. Upon checking the reservoir, I found what I expected, red antifreeze, same thing when I popped the cap to the radiator.
I decided to check the rest of my fluid levels, and found the only thing low, is my break fluid (which was flushed and refilled in late august, and is not green.)
Any idea of what this could be other than anti freeze?
Old 02-01-2011, 11:37 AM
Re: Fluid leaking
To add, I discovered the leak after a 30 min drive, I never had an issue with overheating, and the heater worked fine. This is for a 2002 Avalon
Old 02-03-2011, 04:01 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: Fluid leaking
Did you see it dripping from your car's undercarriage or just notice a puddle? It may have been from another vehicle parked there.
You can also check the puddle by sniffing it for that antifreeze odor. If it really is so, then it's not yours.
Otherwise, I can think of no neon-green-colored fluids in your Av. Old brake fluid can turn a dark green. Some fresh differential lube oils can look greenish, but yours might use transmission fluid instead. Even if it did use gear oil, it would be old and thus dark colored.
Park elsewhere without a puddle and check again.
Hope this helps!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
