Old 01-30-2011, 07:39 PM
20GMC00 20GMC00 is offline
2000 C2500 Sprocket Marks
2000 C2500 350 Vortec.
In the manual that I have, it says that when installing the cam sprocket, the mark on the crank should be at 12 o'clock and the mark on the cam sprocket should be at 12 o'clock also. I have also noticed on the internet that the mark on the crank should be at 12 o'clock and the cam sprocket should be at 6 o'clock.... Which is correct? Thanks
The vehicle is a 2000 GMC. Old body style.
Old 01-31-2011, 10:09 AM
777stickman 777stickman is offline
Re: 2000 C2500 Sprocket Marks
They are actually both correct. With the cam @ 6:00 it's easier to get the marks lined up correctly. However in this position #1 piston is at TDC on the exhaust stroke and #6 piston is at TDC on the compression stroke. Rotating the crank one full turn will put the cam @ 12:00 and #1 piston at TDC on the compression stroke which is were it needs to be to set the distributor correctly.
Hope this helps.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 01-31-2011, 04:24 PM
Wow. Duh. That makes sense. Maybe i should have thought that one through before posting. Thanks.
