Old 01-30-2011, 10:36 AM
Pawl Pawl is offline
2005 Accord 4 cyl Timing chain maintenance
109,000 miles on my car. What type of maintenance needs to be done to this timing chain if any? I know it has a tensioner. Does it need to be checked or adjusted? The manual isnt clear on this. I am changing coolant,serpentine belt,radiator hoses,plugs,....Thanks
Last edited by Pawl; 01-30-2011 at 11:05 AM. Reason: forgot part of what I wanted to say
Old 01-30-2011, 12:25 PM
Autotech3910 Autotech3910 is offline
Re: 2005 Accord 4 cyl Timing chain maintenance
There is no maintenance for timing chains on honda's. Honda hopes that the chain will last the life of the vehicle, however this is not always the case. When I was a Technician at the Honda dealer I don't think I ever saw a timing chain fail under normal operating conditions. I'm not saying it can't happen but it is highly likely that your chain and tensioner are just fine!!
Unless you are noticing abnormal noises from that area or there are any signs of it failing, don't worry about it.
Just continue with all the normal maintenance that should be done at the milage your at.
3100 v6 leaking coolant from timing chain gasket? jamc204 Grand Prix 4 06-22-2010 10:18 AM
Timing Belt kp055174 Accord/TSX/Accord Hybrid 2 07-27-2009 12:00 PM
timing marks/balancer Top Dead Center thehustler211 Problem Diagnosis 1 03-28-2009 11:31 PM
2005 Accord 4 cyl headlights question MarkNYC Accord/TSX/Accord Hybrid 0 10-05-2008 10:54 PM
Timing chain on 4 cyl 95.5 daka Rodeo | Passport | MU 1 01-31-2004 09:10 AM
