Go Back   Automotive Forums Car Chat > Buick > Lucerne
Old 01-29-2011, 06:33 PM
studedriver10 studedriver10 is offline
out side temp sender
I have had the outside temp. replaced twice and it still is acting up, not accurate or dosen't work at all, anyone else experianced this?
Old 01-29-2011, 11:13 PM
consultIII consultIII is offline
Re: out side temp sender
had a similar occurance on a gm pick-up.
for most newer gm ambient temp sensors; they will not update under certain criteria instead displaying the last reading untill the update occurs.
not sure of the location on this model but on the trucks they are located by the rad and installation of bra's, grilles etc. that change air flow near the sensor can skew readings. relocation may be an option if this is the case.
does the temp reading display no reading at all ie. slashes " ---"???
$5500+ Cash Pay Outs KMS & HARRAHS RESORTS Tunica MS smkoss Car Shows 0 01-29-2011 07:37 AM
A/C Cooland Temp. sender on '94 Tracker Lewder Tracker 0 06-21-2005 11:27 PM
420a coolant temp sender to gauge DVSpnoy78 Off-Topic 2 04-09-2004 06:06 AM
Temp out side where you live 97dsmeclipse Off-Topic 16 01-31-2004 07:11 PM
Potentiometer in place of engine temp sender to ECU? CODE4 Off-Topic 4 12-06-2003 06:21 AM
