Old 01-29-2011, 01:27 PM
knl25 knl25 is offline
Need help on coolant leak!!
My 2000 windstar has a coolant leak on the passenger side close to the water pump. My mechanic took a look and said it leaks where the intake manifold gasket is. What is likely to be the problem? Could a bad intake manifold gasket cause a coolant leak?
Old 01-30-2011, 07:06 AM
wiswind wiswind is offline
Re: Need help on coolant leak!!
Yes, it can.
There are 2 possible gasket leaks that would leak near the water pump.
The first is the lower intake manifold gaskets, the other is the front cover (aka timing cover) gasket.
The lower intake manifold gaskets are a cheaper repair job than that front cover gasket.
There are pictures in the pictures that the link in my signature takes you to that show the lower intake manifold gasket job.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
'94 3800TS: power steering and coolant leaks jarl Trans Sport 1 08-03-2010 04:02 PM
'94 TS 3800: HUGE coolant leak - and other fluids jarl Trans Sport 23 10-31-2009 07:53 AM
2000 Blazer lower intake plenum coolant leak Sedatedbylife Problem Diagnosis 8 06-27-2009 10:20 PM
98 Grand Caravan 3.3L Coolant Leak hooperkj Caravan | Voyager 4 04-22-2009 04:17 PM
Please Help / Coolant leak ? CastleRocco Fiero 4 12-05-2004 10:40 AM
