Old 01-29-2011, 11:31 AM
amotagu amotagu is offline
Send a message via Yahoo to amotagu
Angry 2003 Oldsmobile Alero Will not start
I have a 2003 oldsmobile alero that will not start. The other day, we were out of town, drove it and it was fine. We parked it at 11:00 PM and tried to start it at 11:00 AM and it would not start. Five hours later it started just fine and more than once and we made it home. Thursday night at 10:00pm we parked it again. Last night I went out to start it again and it won't start. I tried again this morning and it's still not starting. It's turning over, just not catching. I have key-less entry but not a key-less starter. The lights are working, radio, etc. It just won't start.
The engine turns over but doesn't catch. It's getting fuel, fire, and air. The battery is alive and well. We aren't losing any kind of power so it doesn't seem to be the alternator. Checked and cleaned the air filter. I hope someone can help.
Old 01-29-2011, 12:03 PM
brcidd's Avatar
brcidd brcidd is offline
Re: 2003 Oldsmobile Alero Will not start
Originally Posted by amotagu View Post
. It's getting fuel, fire, and air. .
Here in lies your problem- how do you know you have these three? Proper testing (with numbers) will confirm.
Do you hear the fuel pump running for 2 seconds upon ignition on? With your ear at gas cap (cap off) have someoe turn key to "on" - does fuel pump run for 2 seconds and shut off? If not-- Whaaaaap the bottom of fuel tank when someone turns key to "on" - most likely pump will energize and you can start car. If so, you need a new fuel pump.
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 01-29-2011, 12:15 PM
We know its getting these things because two mechanics tested for them. It's not the fuel pump. And we tried that, it's not the problem. (someone else told us to do that)
Old 01-29-2011, 03:33 PM
brcidd's Avatar
Is your security light on or blinking when in no start mode? Does it go off after 5 seconds if you just turn on ignition?
'99 GMC Yukon
Old 10-11-2020, 10:29 PM
Guru419 Guru419 is offline
My 03 did the same thing the security sensor is being tripped...try using a spare key worn down keys will make it enter security moad and it wont start
2003 Alero will not start, only service engine light comes on with key turned to ACC DelbertJay Alero 2 02-20-2012 04:05 PM
2000 Alero V6 will not start. Please help. slavetothought Alero 1 10-28-2010 08:45 AM
2003 Oldsmobile Alero, Crank No Start eakk5 Alero 4 05-04-2010 09:58 PM
HELP!!2002 Oldsmobile Alero will not start? rosales693 Alero 5 08-28-2007 08:51 AM
2003 Alero will not start LuvGrnFrogz Alero 8 04-29-2006 04:28 PM
Tags
2003 , alero , oldsmobile , starter , trouble-shooting
