Go Back   Automotive Forums Car Chat > Ford > Contour
Old 01-29-2011, 09:12 AM
chaz2759 chaz2759 is offline
Talking 98 contour svt 5sp trans problems
I am having problems shifting in thrid gear. I have to hold the cluch down for 2 seconds and then shift fron 2nd to 3rd or it will grind. What would be the best way to approach this? Is it a common problem? Was there a recall?
Old 01-29-2011, 08:25 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
Re: 98 contour svt 5sp trans problems
Common problem. No recall. Ford went from the dual blocker 3rd gear syncro to the single blocker 3rd gear syncro starting in 1998. You can try anding from Ford friction modifier additive which may help. If not, you'll either have to live with it or pull the trans and have it replaced.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 01-30-2012, 08:43 AM
RoosterBlue's Avatar
RoosterBlue RoosterBlue is offline
yeah, sounds like the synro's not even there... you probably dont even need the clutch (or its basically not doing anything).
with high rev's/speed i bet it wont even go into third?
if the body is rust free, i would spend the money to replace ur 3rd gear syncro, but thats just me.
