Old 01-28-2011, 01:41 PM
Deltadog54 Deltadog54 is offline
Question 98 Blazer Dies/Stalls
98 Blazer, 4.3, 4WD. Dies at idle then after re-start idles rough, seems to loose power while driving (but doesn't die). No codes on the OBDII tester, no MIL's, no check engine light after the die/stall event. I've replaced the fuel filter and the fuel regulator under the plenum (gasket also). I pumped gas out of the tank with the fuel pump discharging into a bowl, fuel looked clean (no water or junk). I pulled the EGR and it looks clean. All wiring looks good. Replaced the rotor, cap and plugs. SP wires all looked good. Also replaced the MAP sensor (just for kicks) still stalls. Fuel pump turns on and runs for 2 seconds like the book says it should and I get 60psi on the fuel rail. I giggled the ignition key and tapped on the CPM to see if it would trigger something....noop.
If........it is suggested to be the fuel pump, do you need to replace the entire unit, or parts...and, is there a sensor or regulator at the pump that could be an issue?
What about the coil, could this be an issue?
Any ideas?
Thanks.
Old 01-28-2011, 02:22 PM
Scrapper Scrapper is offline
AF Premium User
Re: 98 Blazer Dies/Stalls
Any ideas?
Thanks.
what did the cap look like inside when you replaced the rotor button?
Old 01-28-2011, 05:10 PM
Rick Norwood's Avatar
Rick Norwood Rick Norwood is offline
Big Tall Dumb Ass
Vacuum leak? Rough idle is sometimes a fuel mixture problem.
"If everyone is thinking alike, then no one is thinking". - Gen. George S. Patton Jr.
Tags
dies , idle , rough , stalling
