Go Back   Automotive Forums Car Chat > Isuzu > Trooper | SLX | Bighorn | Wizard
Old 01-27-2011, 05:00 PM
Scottyboy3 Scottyboy3 is offline
Water pump question
My 02 Trooper has 132,000 miles on it and needs the timing belt replaced. Is it recommended to replace the water pump at the same time?
Old 01-27-2011, 11:06 PM
boritz's Avatar
boritz boritz is offline
Re: Water pump question
Originally Posted by Scottyboy3 View Post
...timing belt...Is it recommended to replace the water pump at the same time?
Depends:
Are you doing the work yourself? If so, do you mind if you have to go back in later to replace the pump?
If not, it's probably better to have the pump replaced while the mechanic is on the job.
Bottom line - I would (and did) replace it! Along with the hydraulic pusher, tensioner pulley and idler pulley.
Old 01-28-2011, 12:14 PM
Percon Percon is offline
This...
Originally Posted by boritz View Post
Depends:
Old 02-01-2011, 06:04 PM
sassee's Avatar
sassee sassee is offline
At 132K miles, it's a judgement call. I would replace it If it was me. If not, you'll have to pull all of that off again to get to the water pump if it does puke so why not?
2000 Nissan Xterra XS
1989 Isuzu Trooper with a mod or 2
1998 Isuzu Trooper 3.5 with a 5-speed with a mod or 2
1985 Chevy K-10 with a mod or 2
Old 02-10-2011, 09:06 PM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
Any time you tear something down extensively to repair/replace something, it's really a good idea to replace the things you had to remove while you have it apart. Usually if the one part went bad, the rest are not far behind. So yes, replace water pump, oil pump, hoses, belts, etc. if you can.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
