Go Back   Automotive Forums Car Chat > Ford > Five Hundred
Old 01-27-2011, 03:01 PM
scotto4837 scotto4837 is offline
Alternator went out, no warning
If you see these symptoms, watch out. First, I lost a new battery. Replaced it and two months later, the car started rough - kept dying after starting. Then it idled too fast. Then, driving down the expressway the radio went out. Then got ABS warning and Traction Control warning. Lights went out. Car died.
Had to replace the alternator. Problem solved. But, there was no warning other than the above before it simply died on the road.
Man I miss the Charge / Discharge gauge!
Old 01-27-2011, 04:15 PM
old_master's Avatar
Advisor/Moderator
Re: Alternator went out, no warning
Originally Posted by scotto4837 View Post
... the car started rough - kept dying after starting. Then it idled too fast. Then, driving down the expressway the radio went out. Then got ABS warning and Traction Control warning. Lights went out. Car died....
What kind of "warning" are you looking for? The car was practically screaming at you that something was wrong. When you didn't listen, it shut itself off! Most auto parts stores have voltmeters for under $20.
You have to know how it works,
to figure out why it doesn't.
Tags
alternator
