Old 01-27-2011, 02:20 PM
Festivus's Avatar
Festivus Festivus is offline
105k maintenance
2004 Accord V6
So in all reality, do I really need to do more than plugs, timing belt and water pump? I already did my own plugs.
Got a $950 dealer quote for all kinds of belts (timing, ac, alt, ps), valve cover gasket, coolant.
A private shop quoted me $1300.
Dealer quote for timing belt and water pump alone was $589.
2001 Alero 2.4 - 87k - Kid's car - Keeps me busy
2004 Accord EX V6 - 111k - Love this car
2009 Toyota Rav4 Limited V6 4WD - 26k - Wife's car
Old 01-27-2011, 03:24 PM
Scrapper Scrapper is offline
AF Premium User
Re: 105k maintenance
Originally Posted by Festivus View Post
2004 Accord V6
if you haven't changed belts since you owned it you do need to change belts. reason why they want to change water pump is that the water pump is behind the timing belt witch turns your water pump. so in otherwords if you just change timing belt and pump go's out you'll have to tear it back down. also need change gas filter,air filter.
Old 01-28-2011, 01:36 PM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
If not too expensive, replace the tensioner for the timing belt at the same time, sucks to have a good new belt get mauled when a tensioner falls apart...
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Old 01-29-2011, 12:49 AM
Autotech3910 Autotech3910 is offline
Timing belts on hondas NEED to be replaced every 90,000 to 120,000 miles depending on how hard you drive the vehicle!
This is what I would quote a customer at the Honda dealer for a timing belt job on a 2004 accord V6
Timing belt (obviously)
Water pump
Power steering belt( unless it looked pretty new)
A/C / alternator belt (this is one belt)
Coolant (since your replacing the water pump you have to drain the old coolant)
On accord V6 you do not have to remove the valve covers. I do not know why they would quote that for a timing belt job unless they are leaking, then that would be a separate issue.
Also, usually the T.belt tensioner is always leaking(this is a hydraulic tensioner) so in that case it would have to be replaced also.
Then there are times when you remove the T.belt covers and find there are seals leaking that can only be replaced when the T.belt is removed. These seals would include camshaft seals, front main seal, and I believe the oil pump seal.
Yes it will cost a little more to replace these, but it is well worth it because if they go bad later on you are looking at basically doing this same job over again. Since in order to replace them the T.belt must be removed.
Just keep in mind, while YES this is a very expensive repair,
it only needs to be done every 90 to 120 thousand miles! If your timing belt does break which it WILL eventually, it will leave you stranded where ever you are and be even more to fix it then. Since you will have to have your vehicle towed to a repair shop!
Hope this helps
Old 01-29-2011, 02:19 PM
Festivus's Avatar
Yes, thanks for the help. No leaking going on that I know of so I'll get a quote for only what you mention.
