Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 01-25-2011, 07:31 PM
bronco1960 bronco1960 is offline
nustang timing
it is a 4.0 motor the head is crack the book calls out for a tooling to hold the crank and a tool to hold or set the cam do i need the tools 2005 mustang engine code n 4.0l 6 cyl.
Old 02-20-2011, 05:54 PM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Re: nustang timing
Yes, the tools keeps the cam locked in one position so when you remove the followers, the cam does not spin on you, preventing you from miss timing the motor or bending a valve during the timing process. The tool holds the cam in a particular position once you are at TDC.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
