Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 01-24-2011, 04:02 PM
93DOD150 93DOD150 is offline
Will not start
I have a 93 dodge d-150 when i turn the key it will not make a sound, the starter is good, the relay has been replaced. I can hear the fuel pump kickin. i am lost, does anyone have any ideas?
Old 01-24-2011, 04:57 PM
mikefaster mikefaster is offline
Re: Will not start
Sounds like an ignition switch or neutral safety switch...
When you turn the key to the "crank" position, I assume you have no power on the little wire at the starter, right? And if you jump the starter with the key "on", then it runs???
If you go to the relay, I believe the yellow wire comes from the ignition switch; and if I'm not mistaken that yellow wire gets grounded when you crank the key... Try grounding that wire and see if it cranks over (if all else fails, I may be wrong and it needs to have power at the yellow wire; then try that instead-depends how the relay is set up; I'm not there, LOL-- if popping spark is heard & seen and you get momentarily blinded by the light, then do the opposite, LOL)... If it cranks, then the ignition switch on the column is usually bad...
If it doesn't crank, then you may need a neutral safety switch... See if the harness popped off the tranny... Or replace that $6 switch... Also, see if your reverse lights work when you put it in reverse (with the key "on")...
Hope that helps...
2000 Alero V6 will not start. Please help. slavetothought Alero 1 10-28-2010 08:45 AM
97' Intrepid, turns over but will not start. KeithJK Intrepid 1 09-18-2010 11:54 PM
Will not start (sort-of randomly) caffeineaholic Caprice 7 08-04-2010 08:13 PM
1992 Park Avenue Will not start but turns over mattdavidhobby Park Avenue 5 03-18-2010 10:51 PM
Winstar will not start sometimes bwagner61 Windstar 5 02-21-2010 01:04 PM
