Old 01-24-2011, 01:31 PM
joeuser742 joeuser742 is offline
Rear Axel Recall thoughts.
So I took my 03 Windstar for the axel recall. I didn't like what they did; they just put brackets on the places where the axle normally cracks and breaks, then tarred the whole axle. There is still a possibility that the axle could break where they didn't reinforce it.
Also, my uncle brought his 99 Windstar in and they just checked it, said it wasn't cracked, then tarred it; no brackets. Did anyone else not get the brackets?
Old 01-25-2011, 06:32 AM
phil-l phil-l is offline
Re: Rear Axel Recall thoughts.
I've heard about Ford using brackets to reinforce the axle - but haven't seen them yet. Can you share pictures of the brackets?
2000 Windstar LX 3.8
1995 Contour GL 2.5
1986 Mustang GT 5.0 --> Sold, but missed on sunny days
Old 01-25-2011, 08:30 AM
I can do that later tonight. My wife drives the van.
Old 01-25-2011, 10:54 AM
hatethewindstar hatethewindstar is offline
do the windstars with towing package have this recall as well?
Old 01-25-2011, 11:17 AM
tempfixit tempfixit is offline
Maybe this will help:
http://nhthqnwws111.odi.nhtsa.dot.go...0V385-5548.pdf
Old 01-26-2011, 01:59 PM
bigryry bigryry is offline
I would like a pic to, i want to see if they installed the bracket. they told me 6 hours on the phone and they called me 1.5-2 hours later and said it was done. Along with doing the speed control recall. I even questioned them on this and they dismiseed it.
Old 01-26-2011, 04:57 PM
Re: Rear Axle Recall thoughts.
Here's what they look like. As you can see, they did not brace the entire axle. Two brackets, one on each end, then they tarred the axle.
Old 01-26-2011, 05:00 PM
That's not right. They are supposed to have the van overnight to let the glue/tar dry. At least that is what the majority of the dealers are saying.
1998 Blazer 4WD 4.3L 118,000miles 4dr
Repairs
--rear main seal, u/l ball joints, pitman/idler arms, i/o tie rod ends, control arm bushings, motor/trans mounts, oil relocation lines, door pin bushings, water pump, ring/pinion.
--Bad ABS ground, loose connection blower motor, repaired pulse board.
Mods/upgrades
-Throttle plate mod.
1999 Ford Windstar SE 3.8L 160,000miles
Repairs
--P171/P174 procedure, loaded control arms, tie rod ends, shocks, struts, springs.
Old 01-26-2011, 05:35 PM
the metal can't be very thick if they can open the upper part of plate to slide over the axle..
Old 01-26-2011, 07:13 PM
crrobbins crrobbins is offline
Just read on Detroit News online website Auto Insider that Ford announces recall for front end corrosion at front subframe. NHTSA defect investigation 11V030000. Our Windstar is still at dealship waiting for back axle replacement.
Axel recall on ABC News car17fan Windstar 3 12-22-2010 07:23 PM
rear axel replacement help Faze2183 C/K 2 06-27-2004 11:19 AM
'01 4Runner rear axel seal repair Jack0715 4Runner/GX470 4 03-15-2004 01:59 PM
88 s-10 rear axel size likearock S-10 0 07-19-2003 02:35 PM
Rear axel strength Aussie Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 8 02-26-2002 12:15 PM
