Old 01-24-2011, 12:46 PM
FordBoss88 FordBoss88 is offline
02' Grand Caravan Starting Issues
Hello Forum,
My 2002 Grand Caravan has an intermittent starting issue. When starting, it just "clicks", however if you keeping trying it will start perfectly. It used to do it intermittently, but now it does it every time. Please help.
Thank You
Old 01-24-2011, 02:32 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: 02' Grand Caravan Starting Issues
If you're hearing a click it's a good bet the solenoid contacts in the starter are shot. Next time it clicks tap on the starter with a hammer or the like. If it cranks you just proved it. Best way to prove it is to verify 12vdc are getting to both connections on the starter when you turn the key. If the voltage is there you proved the contacts are bad. You can either change the starter or change just the contacts for half the price but more work.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
