08 Malibu Headlight problems
Rat chewed through a wire so I remade the connection. But the problem still exists. When headlights on dim both lights come on but the driver side only shows a low light. When on bright the driver side does not work at all. Checked relays under hood and they are good. Stille need to check relays in trunk.
Re: 08 Malibu Headlight problems
Look on the ground side of the system. A dim light means it has a weak ground, the one that doesn't work at all probably doesn't have a ground at all.
10 hours away from John Deere master certified also master certified ASE tech. Exp. in both. Went to school for cars, wound up staying with Deere dealer for a while, so schooling there too. Also couple years exp in GM and some GM training Gave up wrenching for "Greener Pastures" Current job: RN 2010 Silverado Z71 5.3L 65xxx Wife's 2007 Suburban 1500 LTZ 5.3L 102xxx |
It the same headlight. When on dim it barely shows but when you switch to bright, it doesnt work at all. But the ground sounds like an easy fix, I'll try it.
