Old 01-23-2011, 11:48 AM
450rracer22 450rracer22 is offline
hellp stuck in 4wd
my truck is stuck in 4wd. none of the push button lights are on to change it? any help
Old 01-23-2011, 12:27 PM
j cAT j cAT is offline
Re: hellp stuck in 4wd
check fuses
Old 01-23-2011, 10:07 PM
dorfboy dorfboy is offline
Send a message via ICQ to dorfboy Send a message via Yahoo to dorfboy
What year is the truck?
That would help us to determine what could be wrong with your vehicle.
What it sounds like to me is an internal fault with either your TCCM (Transfer Case Control Module) or your encoder motor. I would check the wires down at the encoder motor first. This is a little easier. Are you getting any check engine lights or service 4WD messages? Let me know and we can go from there.
Old 01-24-2011, 12:38 PM
saturntech's Avatar
saturntech saturntech is offline
Check underhood fuse called ATC, its a 15amp fuse, see this one blow all the time.
Old 01-26-2011, 09:55 PM
i got the lights back workin on the dash, the transfer case fuse was blown on the dash, the 4lo light just blinks all the time, now when i hit the 4hi i hear the relay under the dash click but the transfercase doesnt do anything
Old 01-27-2011, 06:38 AM
saturntech's Avatar
I'm assuming your putting the truck in neutral before trying to take it out of 4lo? If so and your still having troubles it sounds like the actuator that goes into the front diff is not working and most likely caused the fuse to blow.
Old 01-27-2011, 05:02 PM
the transfercase fuse is the encoder transfercase motor . not the locking front diff actuator. the encoder is what engages 4wd ...........
the locking actuator locks the front axle as one , thats all it does !
now your problem may mean it is the encoder motor as defective. the wires to the encoder maybe shorted /damaged. the encoder may have a hole in it. the transfercase may be damaged causing the encoder to blow a fuse due to the internal fork not rotating freely etc...
90% chance it is the encoder motor...make sure the fluid is good/clean blue color..if black or very dark replace first and see if you can get it to work ...
most importantly if you feel this encoder is going to be replaced make sure you place the transfercase into neutral first...
ALL ENCODERS ARE SHIPPED IN NEUTRAL ...YOU WILL HAVE A HARD TIME INSTALLING THE REPLACEMENT ENCODER..MUST LINE UP CORRECTLY..
the transfercase needs to be rotated if stuck in a position other than neutral..never rotate the encoder or it will be damaged.
Problem with 4WD. 2000 sierra k1500 Z71 truckguy92 Sierra 0 09-26-2010 12:56 AM
Service 4wd/Stuck in 4Low Karensworking Sierra 0 06-29-2010 09:03 AM
05 silverado service 4wd steves3424 Silverado 1 05-22-2010 08:55 AM
'02 4wd Issue Shibbychris Envoy 6 03-09-2010 08:35 PM
2001 Rodeo 4wd problems Derman Rodeo | Passport | MU 2 01-20-2010 07:49 PM
