Old 01-23-2011, 07:45 AM
jacespeed jacespeed is offline
,89 s-10 fuel pump?
My '89 S-10 2.5L is slow to start if it has sat for more than an hour and now that it is really cold outside(close to zero) the fuel pump will run for 5 to ten seconds after the engine has been stut off. Is this a check valve problem? A leaky injector? I have checked the spray of the injector using a timing light and the spray pattern is still cone shaped but it is not a nice 'misty' look like I would expect, so the injector might be leaking down. Is my starting problem related to the pump or the injector?
Old 01-23-2011, 11:52 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: ,89 s-10 fuel pump?
Not usless you aare losing fuel pressure and or injector pulse on cold cranking.
What oil are you using?
Does engine crank over normal cold?
When was last good tune up?
How is plugs and filters?
Any codes or check engine lights?
What is fuel pressure cold cranking?
MT
Old 01-24-2011, 02:08 PM
new cap, rotor, wires, plugs and air filter in the last 2000miles. I am not sure how to check the fuel pressure on this truck. I do have the guage to do it though. any Ideas on how to hook a guage into the fuel line?
Old 01-24-2011, 03:55 PM
MT-2500's Avatar
AF - Advisor
Hook into the line at fuel filter.
MT
