Go Back   Automotive Forums .com Car Chat > Chevrolet > General Discussion
Old 01-22-2011, 04:51 PM   #1
muff34
Rislone liquid copper block seal
has anyone ever used Rislone liquid copper block intake & raditor stop leak in an attempt to seal leaking intake manifold gaskets? Gm 3.4 with 85000 miles.
Life Is A Highway ,Enjoy The Ride
muff34 is offline   Reply With Quote
Old 01-22-2011, 07:04 PM   #2
MT-2500
AF - Advisor
MT-2500's Avatar
Re: Rislone liquid copper block seal
Stop leak and dope only creates more problems.
If intake is leaking stop leak will not seal the pastic gasket crak out.
Get a FEL-PRO problem solver solid rubber/metal intake gasket set and be done with it.
MT
MT-2500 is offline   Reply With Quote
The Following User Says Thank You to MT-2500 For This Useful Post:
muff34 (03-19-2011)
Old 01-23-2011, 11:41 AM   #3
j cAT
since you know this is a gasket failure any stop leak will only slow down the leak for a while.. If your coolant system is corroded or has a lot of debris in it from lack of coolant maintenace you could damage the engine .
as the metal expands / contracts this gasket leak will continue to leak ..gasket and the metal mating surface is usually damaged from corrosion.
j cAT is offline   Reply With Quote
Old 01-23-2011, 02:00 PM   #4
danielsatur
Did you do any Test's?
Visual Inspect
Coolant pressure test
Smoke test
Symptoms-
Is the coolant reservoir tank contaminated with oil/gas?
Is there coolant in the block?
Is there any shortage of coolant?
Over Heating.
1) Replace any bad rubber hoses, or water pump.
2) Replace Intake gasket if Bad
3) If Radiator, or heater core, I would consider Metallic block seal.
3) If a bad Block, or Head gasket, I would consider http://www.steelseal.com , or blue Devil.
Go to any Auto Parts store, and ask what's the most perffered by mechanics.
If the block, heads, or head gasket is bad, it's worth the try!
danielsatur is offline   Reply With Quote
Old 03-19-2011, 09:36 PM   #5
muff34
It`s a done deal. New fel-prob gaskets installed.......lol
Old 03-20-2011, 07:41 AM   #6
MT-2500
AF - Advisor
MT-2500's Avatar
Sounds GOOD.
Thanks for posting back the repair.
MT
Old 05-12-2012, 10:28 PM   #7
RaulSoler
Red face Re: Rislone liquid copper block seal
I used liquid copper Rislone to seal a head because one of the spark plug was showing some water due to a crack in the gasket. It works perfect but i donīt know for how long, some mechanics tells me it would last some 2 or 3 months, others tells me up to one year. The thing is that the first time this momentaneus solutions brough me another problem: a hose stocked and broke because in one corner of it the sealer accumulated and became hard way to the water to circulate.
My car is a Honda Accord 2000 VTEC 4 cil.
RaulSoler is offline   Reply With Quote
Old 05-13-2012, 09:35 AM   #8
j cAT
I don't know how you are sure it was a gasket issue. if this is a crack/or metal defect causing the leak into the cylinder it should hold. If its a gasket especially on the heads this may not last very long.
using these products the system must be clean. if you have lots of corrosion and mineral deposits from the use of non distilled water these sealer products cause all kinds of coolant retrictions. using too much product all at one time is not recommended.
I never used this product. I have used another product with good results .
