Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 01-22-2011, 01:52 PM
Allegretto's Avatar
Allegretto Allegretto is offline
Send a message via Yahoo to Allegretto
2001 Impala Radiator
I have a 2001 Impala with the 3400 engine and it needs the radiator replaced. Any idea on how easy/hard this is to do myself? any tips or suggestions are welcome. thanks guys
Old 01-23-2011, 10:30 PM
dorfboy dorfboy is offline
Send a message via ICQ to dorfboy Send a message via Yahoo to dorfboy
Re: 2001 Impala Radiator
It should be very simple actually. It has been a while since I have taken one out in one of these cars, but you will need to drain the cooling system first. Disconnect the upper and lower radiator hose. Disconnect and cap the transmission cooler lines so they do not leak all over. Disconnect the electric fans and remove them. There are two 10mm bolts, one on either side, and then the fan assembly will slide in at the bottom. Once bolts are removed, tilt the assembly back towards the engine and pull up. Then the radiator is removed in the same sense. You just need to make sure of proper disposal of old antfreeze.
http://www.impalaforums.com/diy-do-i...lkthrough.html
2001 impala 3.8 radiator removal question? mitch_houser Impala | Impala SS 3 07-25-2010 02:25 PM
2001 Durango 4.7L radiator drain plug mcknt Durango 0 09-26-2009 12:52 AM
2001 Impala Keyless Entry kdp Impala | Impala SS 9 01-09-2007 06:45 PM
Reprogram New Radio - 2001 Impala twhiting Impala | Impala SS 4 03-11-2004 06:21 PM
2001 Impala Keyless Entry Recode Dervish Impala | Impala SS 3 07-26-2003 06:40 AM
