Go Back   Automotive Forums Car Chat > Toyota > Tundra
Old 01-22-2011, 09:32 AM
jammyjim jammyjim is offline
Stop light relay
The brake lights are out in my 06 double cab. I have power at the brake switch on the pedal, but none of my lights come on. I got a wiring diagram that shows a stop light relay behind the instrument cluster. I removed the cluster, but the relay was nowhere to be seen. Does anyone have any idea where it could be, or any ideas about common brake light failure points?
Old 02-20-2011, 04:35 AM
killdaggy killdaggy is offline
Re: Stop light relay
Just check the relay inside the ICU box. that is located right side under the hood. Or try to see if there's a wire grounded or maybe it was just cut.
2003 Accord, AC stops working, relay problem? ggoelzer Interior | Audio | Security 0 04-08-2010 10:26 PM
2001 Caravan Stop lights out RickCox Caravan | Voyager 0 04-05-2010 01:13 PM
96 pontiac sunfire engine just stopped at stop light then turned over on restart chris_friday General Discussions 3 10-30-2005 08:56 AM
OK, quick, should I bid on the stop sign or on the stop light? ec437 COMPLETELY off-topic 21 09-24-2004 09:38 PM
93 automatic se jerky when going up hills after sitting at stop sign or stop light?! Diablo_VT Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 1 10-06-2003 11:43 AM
