Old 01-18-2011, 04:03 PM
[email protected] Milway16@yahoo.ca is offline
96 Blazer heater blower problem
The heater blower just stopped working. I checked the fuses and they are ok. When I turn the heater switch on nothing happens. Any ideas/
Thanks
Wayne
Old 01-19-2011, 02:44 AM
viggy58 viggy58 is offline
Re: 1996 Blazer starting problem
only the heat? or the blower in general?
mine actually managed to suck a parking ticket up off the floorboard, which jammed it. removed the ticket and it started working again just fine.
2001 Chevy Blazer
4.3L 5 speed manual
Alpine deck, Type R 12in. sub.
145k miles
1997 Pontiac Sunfire
2.2L automatic trans
146k miles
Old 01-19-2011, 10:24 AM
It is still producing heat just not blowing so I am thinking maybe the heater blower motor needs to be replaced.
Old 01-19-2011, 09:02 PM
blazes9395's Avatar
blazes9395 blazes9395 is offline
Newbie mod
Re: 96 Blazer heater blower problem
When you turn it to the high position for the switch, does the blower now work? If it doesn't check your connection at the blower, and probe it to see if it has power going to it. If it has power, your blower motor is bad, if it has no power, check your fuse, check your wiring to find your open in the circut.
Since you mention you checked your fuse, pribe the wiring at the blower to check for power.
Heater blower? problems superpsychocow Bonneville 16 02-10-2007 04:31 PM
94' Blazer a/c heater blower problem jdsmith27 Blazer 4 07-25-2005 10:17 PM
1999 Malibu heater blower problems PhoenixSandman Malibu 2 10-12-2004 06:41 AM
Headlight/AC Heater Blower Problems PrixGT Grand Prix 1 10-05-2004 09:49 AM
Heater Blower Problem on 328 christopher salata 3 Series 11 03-23-2004 07:40 PM
