Old 01-19-2011, 02:23 AM
93plygravoyse 93plygravoyse is offline
1993 Plymouth grand voyager headlight adjustment screws
Where are the adjustment screws for this model? I have searched high and low on the web in my Chilton. I have looked all around the light etc. I am lost pics would help. thanks
Old 01-19-2011, 11:03 PM
George1 George1 is offline
Re: 1993 Plymouth grand voyager headlight adjustment screws
Similar problem I am having. I think they are accessed by pulling the headlight assembly. I haven't checked mine yet to see.
Old 01-28-2011, 11:00 PM
Autotech3910 Autotech3910 is offline
The adjustment screws are located in holes in the crossmember right above the headlights. You will need a 3mm hex socket in order to adjust these. These are not regular Phillips or flathead screws. When I tried to adjust the headlights on my voyager both adjusters on both headlights were seized in place! If you try to turn the adjusters and they will not turn, then you probably have the same problem. In order to fix this you will have to remove the headlight assembly. After it is removed you will have easy access to to the adjusters and should be able to free them up by spraying some WD40 or some type of oil on the threads of the adjusters and slowly turn the adjustment screws back and forth until they move freely. Then you can reinstall the headlight assembly and properly adjust them. I will try and send a picture of their location from my service manual. If you have any other questions let me know.
