Old 01-18-2011, 01:54 PM
scoutinkeith's Avatar
scoutinkeith scoutinkeith is offline
Send a message via AIM to scoutinkeith
05 grand caravan blower motor resistor pack?
On my Mother-in-law's 05 grand caravan, the heater fan/blower has become stuck on hi. Even with the climate control is shut OFF, the fan continues to blow on hi. The searching I've done has lead me to believe that it is a problem with the resistor pack(on the bottom of the blower, in the passanger foot well). Dose anyone know if there is a way to test the resistor pack to confirm that it's bad? I'd like to make sure before she has to spend $100 for a new part.
Oh, and I found some info that suggested the relay, but I checked that, and it's still good, that's why I'm thinking that it's the resistor pack.
when all else fails, get a bigger hammer.
Vehicles:
2005 suburban 1500 4x4
all stock, ex-fire department truck.
1987 Grand Wagoneer
Old 01-18-2011, 05:12 PM
cbwilsha cbwilsha is offline
Re: 05 grand caravan blower motor resistor pack?
It IS the Blower Motor Resistor, you have tested it, and it costs much, much less than $100 ( if you have manual AC) and takes only a few moments to replace.
C.B.
Old 01-18-2011, 05:21 PM
b1lk1 b1lk1 is offline
Check the plug, they are also known to have problems. I changed my resistor only to have the plug melt and short out the new resistor 3 months later. Now I need both, lol.
Old 01-18-2011, 05:33 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Resistor blocks are used on manual temp control systems. Cost $15. Blower motor control modules are used on automatic temp control systems. Cost $80. On your model year they are both located in the same area behind the glove box. Here's a video that talks about the resistor block: http://www.youtube.com/watch?v=AS2mVNV2NFk
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 01-18-2011, 08:47 PM
Ok, I guess it's a control module then? The van has the 3 zone automatic climate control.
so is there any way to determine that it is in fact the module that is bad? I'd hate to replace the module, only to find out that it's the switch that's bad.
Vehicles:
1987 Grand Wagoneer
Old 01-18-2011, 11:02 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Looks like you can disconnect connector C1 on the blower controller and measure the volts at contact #3 (dark blue/light blue wire) as you rotate the blower speed switch. If you see a voltage change from speed to speed your switch is good. Not sure what volts you should see.
Old 01-19-2011, 08:24 AM
Only if you have the electronic climate control. I have 3 zone heating with manual controls and it has a regular resistor.
Old 01-19-2011, 08:25 AM
NhocCuteGirlz NhocCuteGirlz is offline
Banned
C.B.
Old 01-19-2011, 08:42 AM
RIP, thanks for the reply, I'll test it when I get home tonight, thanks again.
b1k1, I'm going to assume that it has a control module. It dose have manual adjustment, but it also has an "auto" feture. when "auto" is selected, the temp is manualy changed, but the fan speed adjusts automatically.
Vehicles:
1987 Grand Wagoneer
Old 01-19-2011, 05:50 PM
I just came in from testing. Assumeing I had the correct wire, I tested the center wire of the plug on the left side of the control module(I took pics of the plug and wire that I tested, but can't post them until tomorrow morning).
there were three wires on the plug, the left wire is black/orange, center wire is blue/lt blue, and the right side wire is dk blue. I tested all three,
left side, black/orange = no voltage at any fan speed setting.
center, blue/lt blue = no voltage at any fan speed setting.
right, dk blue = 11.9 v at all fan speed settings.
Am I correct in assuming that this means that the switch is bad?
Vehicles:
1987 Grand Wagoneer
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
