Old 01-18-2011, 01:32 PM
tsto tsto is offline
Radiator fans run nonstop.
We have a 2006 Grand Caravan and the radiator fans run nonstop. I've checked the fuse box and there is no relay designated for the radiator fans only a fuse. I've located a metal block riveted to the front frame (bumber) area in which the fans wiring run to. Is this a relay? What could be the problem?
P.S. the car was sitting in the garage for hours in 20 degree weather and the fans just started to run.
Thanks
Old 01-18-2011, 02:00 PM
danielsatur danielsatur is offline
Re: Radiator fans run nonstop.
Not good, because of poor emissions, wear, and Tear on your electric coolant fan.
Suspect a bad sending unit for coolant fan, or a stuck on relay.
Old 01-18-2011, 05:50 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
You've found the radiator cooling fan relay and it is the problem. Not a typical electro mechanical relay but, a solid state pulse width modulated "switch" that gets very hot, therefore, it uses the frame and surrounding air as a heat sink for cooling. They regularly fail making the fans stay on or not come on at all.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 04-14-2012, 08:01 PM
tonytog tonytog is offline
Hi I am having he same problem on a 1998 Voyager witha 3.3 engine Is The Radiator Fan Relay Swich is Located in the same area and look the same on my year and make??? Any help would be appreciatted.
Old 04-15-2012, 12:57 AM
RIP's Avatar
RIP RIP is offline
AF -Advisor
No and no. On your van it's mounted on the frame down low next to the radiator and has no cooling fins on it. This video should get you there: http://www.youtube.com/watch?v=AdIYm9kM5E0
Tip. Spin the fans by hand to make sure they aren't binding. A binding fan can draw higher current and fry the relay.
The Following User Says Thank You to RIP For This Useful Post:
tonytog (04-15-2012)
Old 04-15-2012, 06:57 PM
Thanks Rip, I can see it under the air box. It will be a day or two before I get around to changing it out. Use the other car for a few days. Thanks I ll check back to tell everyone if it worked. How hard is it to remove the air box???
Old 04-15-2012, 08:01 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Couple of bolts at the top, loosen two clamps on the air ducks and pull off a small tube. Not at all hard to do.
Old 04-17-2012, 07:17 PM
Smile Re: Radiator fans run nonstop.
So i needed an excuse to take a day off from work anyway. so I took today. Went to 2 auto part stores and neither had the relay in stock. so I got one from the dealer. Not to bad $65.
Air box came out easy enough once I figurged out the airfilter box was a separte piece from the intake tube piece.
Replaced the relay after figuring out the "clip". The red slide is obvious enough But I havent done something like this in awhile and thought you "Lifted " up on the tab like we used to. Accedently pushed down on it and poped right out. Took longer to unclip the thing then to do the whole job.
Needless to say WE HAVE FANS. Good day to test them too. In NY today was 85 degress and ran with the A/C on and off and temp gauge stayed right were it has always been.
So thanks again to RIP and everyone else on this wonderful forum.
Old 04-17-2012, 07:18 PM
Oh and the faans do spin freely.
94 thunderbird radiator fan/ temp gauge problem frustrated by now Thunderbird 19 08-09-2009 11:05 AM
Electric radiator fan runs slow gatordp Grand Cherokee | Grand Cherokee SRT8 1 07-16-2005 11:29 AM
radiator fan runs all the time JDW Caravan | Voyager 5 04-04-2005 10:59 PM
Radiator Fans running with engine cold smithsr1287 Camaro Discussions 4 01-28-2005 07:53 PM
1987 Jetta Radiator Fan Runs Skier7667 '83 - '90 1 04-05-2003 07:43 AM
