Go Back   Automotive Forums Car Chat > Buick > Century
Old 01-15-2011, 05:00 PM
scotts96gt scotts96gt is offline
Sloppy steering
Recently my wifes 99 Century has developed what i call sloppy steering. There is no noise coming from the power steering pump although i do believe i have a leak there. It drives straight. Even in a turn/curve if you let go of the wheel it continues in that same path and does not straighten out. If you are in a gradual curve you can actually go through it without touching the wheel because it just stays there. It is not difficult to turn and like i said no noises. Living in michigan its like plowing through snow with the gas pedal to the floor with the wheel cranked to one side, it just does not self correct. It becomes most frightening when switching lanes on the expressway and you bounce between the lines a few times before the steering settles out. Hope someone kinda understands what im tryin to convey here and point me in some sort of direction as where to start.
P.S. The vats and passkey security systems are a joke. I have posted on here couple times about this issue and have met with similar results as others... You cut the wires from the ignition switch and the car starts every single time no problems. So just for reassurance i bypassed the switch with a resistor pack to match my key and have not had a problem since. I figure if it will start with the wires cut its not much of a security system but more of an inconvenience on mine and a possible thiefs part.
Old 01-16-2011, 02:48 PM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
Re: Sloppy steering
Have you checked for any worn out suspension parts? These can cause wander and the steering not to return to the center.
Some time ago my TC had the same problem, the wheel wouldn't turn back to the center, and the problem was a broken seal at the steering pump, but being very different configurations I'm not pretty sure they can be related.
Best regards,
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
Old 01-16-2011, 03:07 PM
Scrapper Scrapper is offline
AF Premium User
Re: Sloppy steering
a power sterring could have went bad that would cause your problem. get the rack checked and if you want to try this take right front wheel on left front and vise versa left to right and see if it pulls the other way because it may quit pulling or it can pull the other way than it is now. also get front end checked after you try the wheel thing i said to try. my mom and dad drove p/a's and never had a problem in steering at all. only the stable lizer links and bushings and if there broke it will go all over the road like your saying.
good luck...
sxrapper.....
Old 01-17-2011, 08:21 AM
Re: Sloppy steering
The steering needs to be centered by the driver if you turn left or right. Last night i noticed a bit of creaking sound if i was at a complete stop and then began making a right or left turn. I am losing a bit of power steering fluid, filled the pump and still have the same problem. Would the rack possibly be leaking fluid seperate from the Steering pump or vise versa? I can do the stabalizer links quite easily so that might be the first thing to try. Any other suggestions would be appreciated.
Old 01-17-2011, 11:55 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: Sloppy steering
Do you have any unusual tire wear? It sounds like an alignment issue for sure, which could be caused by worn/bent suspension parts either due to mileage or a small impact such as a big pothole (I live in Flint, so I know there are plenty in your area...) or hitting a curb.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 01-17-2011, 12:41 PM
Re: Sloppy steering
Tire wear seems to be normal and even. accleration and stopping while not holding the steering wheel the car still goes straight. I have already replaced both lower control arms and outer tie rod ends and had an alignment done. I had a loud clunking in the front end and it would bounce terribly when going over bumps in the road along with the steering issue. So far what i have done has fixed everything except the the steering. Is there anyway i can test myself the power steering pump and the rack?
Old 01-17-2011, 02:48 PM
richtazz's Avatar
Re: Sloppy steering
The information added in your last post would indicate a bad strut/strut mount/bearing. The upper strut mount has a bearing plate that the spring pivots on, and when they go bad, they cause exactly what you're describing (clunking, no auto-return) as well as the creaking you described in post #4.
Old 01-17-2011, 08:15 PM
Re: Sloppy steering
When i go to Autozone what should i ask them for then? Would that mounting plate be all that i should need to replace? How difficult a job is it for a pretty experienced DIYer?
Steering Wheel Repair JDatx512 Tacoma 0 03-30-2009 12:55 PM
Problem with the steering wheel Ennar Aveo 5 03-03-2009 09:11 AM
Sloppy Steering Questions BeachBlazer Problem Diagnosis 9 02-20-2009 09:36 AM
Sloppy steering in '89 E-150 Stale Trooper E Series 1 04-02-2007 11:03 AM
sloppie steering frogman6042 El Camino 4 11-27-2006 12:45 PM
