| F Series Forum covers questions and discussions regarding Ford F-150, Ford F-250, Ford F-350, Ford F-450, Ford F-550, Ford F-650, and Ford F-750. |
2002 4.2 hard to start
ive got a 2002 f150 4x4 with a 4.2 i have egr insuffient flow code and bank 2 running rich also sometimes i get cylinder 2 misfire and misfire in first thousand revs it sometimes struggles to start but sometimes it starts right up
i took it to a shop and they said it had low fuel pressure so new pump and tank( old one was rusted) its a bit better but still really struggles sometimes wat else could be causing this i was thinking changing the plugs to help misfire and cleaning the egr ports and then if that doesnt help a new dpfe sensor could it still be somethin with fuel pressure ? or wat esle can i do to fix the hard starting and engine codes??? |
Re: 2002 4.2 hard to start
anythin any suggestions anyone
1)A bad, or dirty MAF sensor is a symptom of a cold hard start.
2) Insuffient flow to EGR, take the throttle body off, clean EGR, and EGR gase passages @ the same time without removing the EGR valve. |
if the MAF sensor was bad wood i not be getting a code for it? and how wood you clean it?
A MAF sensor only seems to throw a code when it's a hard fault.
1) You can buy CRC MAF sensor cleaner, and a air filter at any local Auto parts store. 2) Clean both the MAF sensor and electrical connector, use a dielectric grease for electrical connection. 3) Roll the spark plug and wire from cylinder 2 to another pos. 4) Reset an clear code. Notes - Cylinder 2 is on bank 1 (passenger side) Bank 2 - Running rich , Suspect upstream H02 sensor How many miles are on this truck? If over 120K miles, it's time for a new air filter,fuel filter, plugs, upstream H02 sensors, and probably a new MAF sensor. Caution - Lets get this problem fixed, befor you damage your catalytic converters. |
203000 km on the truck i have replaced all the filters and everything but the plugs when i bought the truck a few months ago
its winter hear and i dont have a heated shop so i was planning on changing the plugs in the spring when it warms up a bit if plugs do not do it then your saying its the upstream o2 sensor on bank 2 and ill try cleaning the maf sensor before i replace it they are kind of pricy |
ok so to clean the erg passages what am i supposed to do you said take the throttle body off?
