Old 01-14-2011, 05:03 PM
wagslick wagslick is offline
99 Silverado Shift Lever loose
While on my way to sell my 99 Silverado 5.3 L engine LT to another fella, I stop for gas and the shift lever has no resistance. Truck is stuck in Drive and the shift lever just falls to it's lowest position. This sucks. Any idea what to do?
Old 01-14-2011, 05:32 PM
777stickman 777stickman is offline
Re: 99 Silverado Shift Lever loose
Sounds like the cable to the tranny became disconnected from the lever. Either under the dash or at the tranny. Or something broke in the column.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 01-14-2011, 06:09 PM
slo99sierra slo99sierra is offline
I don't believe it's the cable. It's in the shifter mechanism in the column. Inspect the cable anyways just to cover your bases. It is a 2 peice cable, and it joins on the driver side, underneath the cab, it will be prominent.
To put it in Park, you need to physically go underneath and push the lever the cable is on, all the way toward the front until it stops. It will go into Neutral, Reverse, and then Park.
-Be prepaired take apart the dash bezel, knee bolster and column covers. The bezel uses clips, so just pry it off.
-The knee bolster will need a 7mm socket
-The column covers need either a T20 or T25 Torx head (use a torx driver if you have one!)
-Grab a Chiltons or Haynes repair manual and look up the shifter mechanism
-If you can't find anything in either one, PM me and I'll shoot you a message back with pictures and instructions on the repair. I have a subsription to AlldataDIY. Very handy.
Old 01-14-2011, 06:53 PM
Re: 99 Silverado Shift Lever loose (with pics!)
HA! Amazing! That's exactly what happened. Crawled under the truck and saw the linkage was simply disconnected. Squeezed it back on with some pliers and I'm good to go. Easiest fix ever. Wonder why those things come apart in the first place?
Here are some picks of my fix.
Old 01-14-2011, 07:08 PM
Well. I guess when it's in drive and it separates like that the shifter will drop down.
It must have been coming off little bit my little bit and finally popped off when the motor and trans torqued just right. I've never had that issue...but I won't experience because I have a B&M Quicksilver ratchet shifter now.
Old 01-15-2011, 08:58 AM
j cAT j cAT is offline
that was damaged when they dropped the tranny pan..
that pivot point does not JUST pop off....
Old 01-15-2011, 10:48 AM
Ah yes. I searched the OP's threads and found that he had the fluid flushed and replaced. Could be a possibility that this is what happened.
Old 01-15-2011, 12:43 PM
with this set up it is common for the hacks to use force to bend this out of the way for pan removal , instead of removing the torx screws on the bracket mounting hardware..
Old 01-28-2011, 03:16 PM
3mikeman 3mikeman is offline
This just happened to my 99 Silvy. My cable end seems to be worn out it won't stay clipped to the lever even after i bought a new lever. What I ended up doing was taking off the lever grinding down the back side of the pin and hammering out the pin and drilling a 1/4 hole for a bolt and bolted it together. I hope this would be a permanent fix if not i hope it at least gets me thought the rest of winter since it's my plow truck and replace the cable in the spring. I hpoe these picture come out.
Old 01-28-2011, 04:28 PM
inafogg inafogg is offline
as long as the cable can rotate freely when shifting, & nut does'nt
come loose.. you should be fine for awhile
good luck
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
Old 01-28-2011, 10:20 PM
Locknut plus thread locker on it so it should stay put...
