Old 01-13-2011, 09:39 PM
Meck46 Meck46 is offline
Rear wheels lockup
hi my friend has a 94 chey 1500 4X4, 5.7L engine, after he got stuck in a snow bank, when ever he drives it the back wheels lockup, I checked the diff and rear brakes every thing is good, could it be the transfer case or the trany thats locking up.
Old 01-14-2011, 04:30 AM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: Rear wheels lockup
When does it lock up, when he accelerates? When he hit the brakes?
He may have crushed a brake line, so the brakes are slow to release, after they are applied. Or a parking brake cable got snagged or bent, locking the brakes on.
Old 01-14-2011, 08:38 AM
hi it locks up when you give it gas, I put the truck on jack stands and put it in drive 2 wheel then 4 wheel drive it doesn't lockup till I give it gas if I let off the gas it unlocks, it does the same in 2 wheel or 4 wheel.
Old 01-14-2011, 08:45 AM
j cAT j cAT is offline
check the rear wheel bearings ..could be these got damaged when stuck in snow..this can cause the brake shoes to drag ..
Old 01-14-2011, 09:01 AM
Hi there is no noise or movement in the rear wheels or brake drag both rear wheels spin freely, would a transfer case lockup like that or is it direct drive in 2 wheel.
Old 01-14-2011, 09:46 AM
Scrapper Scrapper is offline
AF Premium User
i to would look for a pinched line or have you tried looseing the parking brake? try this unplug vaccum line from brake power booster and see what it does but when unhooked the pedal will be hard as a rock and see if it locks up?
Old 01-14-2011, 01:19 PM
Here is what I tried put the truck on jack stands put it in drive gave it some gas it would lockup at this point I had a friend see if he could spin the back wheels and sure enough they ar free so I do not thing there any problem with the brakes or line, if it was a line you wouldn't be able to ture the back wheels so easy after pressing the brakes or if e-cable was stuck the wheels whould not ture as easy after appling them, I also pulled the pan on the diff and no broken teeth or any thing out of the norm. So Im thinking its either the trany or the transfer case because there is a clunk under the truck when it lockup.
Old 01-14-2011, 03:39 PM
could be the transmission snapped a gear...
Old 01-14-2011, 05:16 PM
777stickman 777stickman is offline
Also check the drive shaft and u-joints very closely for any damage.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 01-14-2011, 09:03 PM
AF Premium User
ok now i agree with you on that tranny. i just wanted to know because i'll never by master cyl at auto zone the front brakes locked up with bad master cyl and had to unhook vaccum line going to booster to let them realese and it was there dam master cyl. i've changed and bench bleed so many and never had a problem this time it was there fault but my fault buying it there.
Old 01-15-2011, 10:47 AM
Now the question is, could it be the transfer case or just the trany, has any one herd of a transfer case locking up? The truck drive as if someone throughs the shifter into park when you give gas, when you let off the gas its back in drive. So Im thing its the trany.
Old 01-17-2011, 11:03 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
If it does it in 2wd, then I'd say it's in the tranny...the transfer case acts like a pass-through at that point. But you can also shift the TC into neutral and at least listen for that clunk of binding gears if it's happening in the tranny.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
