Go Back   Automotive Forums Car Chat > Ford > Five Hundred
Old 01-13-2011, 08:05 PM
Franco2112 Franco2112 is offline
Cool New Sway Bar/Bushings Still Squeaks Going Over Bumps
Just replaced worn out sway bar bushings on 2005 Five Hundred FWD SEL with 111,000 miles. The new sway bar from Ford dealer has the polyurethane rubber bushing that are design to make less noise yet the don't. Note that this noise only happens when the outside temp is below 40 degrees f. There are no grease fitting to lube. Anyone have this problem and how did you fix. Thanks
Franco
Old 01-13-2011, 08:07 PM
danielsatur danielsatur is offline
Re: New Sway Bar/Bushings Still Squeaks Going Over Bumps
How about front struts?
Old 01-13-2011, 08:12 PM
Front struts and mounts are new. Stabilizer links are new. Front end very tight. No other noises, just from the sway bar bushings.
Franco
