Go Back   Automotive Forums Car Chat > Toyota > GS300/GS400/GS430/Aristo
Old 01-13-2011, 02:56 PM
printer2222 printer2222 is offline
Lexus 2003 GS 300 VSC warning light
i have a 2003 lexus gs 300 and the VSC and check engine lights come on. They have come on before and I have replaced all of the sensors and even the catalytic converter. i have spent about $ 1,600 and they went 3 months being off and now the same warning lights are on again. any suugestions to fixing?
Old 01-24-2011, 11:51 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: Lexus 2003 GS 300 VSC warning light
Please post the trouble codes that are stored in the ECM. You can usually have them read for free at any auto parts store (California is a known exception).
Problems with VSC (vehicle stability control) would usually point to a faulty or dirty wheel sensor, connector, or wire, and possibly an accelerometer-type sensor. This may require an ABS-capable code scanner, but see what you can pull from the ECM with a normal code reader.
I do not know how a new cat converter would be related to VSC problems unless you had problems with the emissions system as well.
Bottom line is...when you have the codes read, ASK TO SEE THE READOUT and write the code numbers down. Don't just ask for their interpretation.
Good luck and welcome to AF!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
