Go Back   Automotive Forums .com Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 01-13-2011, 03:24 PM   #1
Mooney58
89 Olds Ceira 3.3 V-6 won't start.
I have a 89 Ciera that has been a very reliable car since day 1. The car has 157,220 miles and still runs like a scalded dog until now. 4 days ago I had taken it to the store,shut the key off and it never started again. After towing it home I scanned the OBD only to find my serpentine belt had 1 rib sheared off by a broken alternator bracket, wrapped around my crankshaft behind the balancer and slapped my Crankshaft Positioning Sensor to shreds. After installing a new sensor and gaping it 3 different times, I get the same results. It tries to start,but ends up sputtering and backfiring and shuts down almost immediately. I am a back yard mechanic,and have always enjoyed fixing my own cars.I'm stumped, Please Help Me !!
Last edited by Mooney58; 01-13-2011 at 03:27 PM. Reason: Notice incorrect spellings
Mooney58 is offline   Reply With Quote
Old 01-13-2011, 03:38 PM   #2
maxwedge
A990 racer
Re: 89 Olds Ceira 3.3 V-6 won't start.
Make sure the tone ring on the damper is not damaged, or the wires in the connector are not pulled out slightly.
maxwedge is online now   Reply With Quote
Old 01-16-2011, 01:58 PM   #3
Mooney58
Thank You Maxwedge for your advice. I'm not sure which one your refering too as the tone ring since there are two rings that run trough this sensor,but I'll check both of them for damage and make sure once again that the wiring connecting to the sensor is good. I wish I knew the ohm rating for this sensor to make sure that the sensor is not defective ! should you know,I would appreciate feedback on that. Thanks again...
Old 01-17-2011, 02:36 PM   #4
maxwedge
A990 racer
I forgot what it should be but google or do a sight search for the ohms reading you will find it.
