Old 01-12-2011, 12:48 PM
Dcving Dcving is offline
Cooling Fan Assembly Upper Bolt
well i was taking the upper bolt that holds the cooling fan assembly to the radiator and a plastic clip must have snapped because the bolt turns freely, now i want to know if i just pooched my rad because of that or is it just a piece of plastic that broke off
would i be able to just take a dremel and cut the little piece off and be good to go?
has anybody else experienced this?
Old 01-14-2011, 05:11 PM
krivasauto krivasauto is offline
Banned
Re: Cooling Fan Assembly Upper Bolt
What engine do you have?
Old 01-14-2011, 10:17 PM
3.5
Old 01-15-2011, 11:00 PM
Banned
I thought the bolt goes into a speednut that is on the radiator support. Should not have affected the radiator, but to fix it you need to remove the fans and the radiator retainers and put in a new speed nut.
Old 01-15-2011, 11:01 PM
thanks man i will do that, im putting it back together tommorow after an altenator job
Old 01-19-2011, 09:20 AM
Banned
I have found this job to be easiest by removing the battery, battery tray and thermostat housing. If you do, don't forget to bleed the cooling system. If you do it by removing the compressor, don't mix and match the compressor and alternator mounting bolts or you will crack the head and cause a coolant leak. Don't ask me how I know.
Old 01-19-2011, 10:51 PM
haha thanks man i read your site like a bible, it helped me a lot...its running and on the road now
