Go Back   Automotive Forums Car Chat > Dodge > Durango
Old 01-12-2011, 12:03 PM
chilsonj chilsonj is offline
Angry Unfamiliar noise...
It is kind of like a howling noise coming from under where the air filter is. No gauges have come in but when I rev the engine or hit the gas it sounds like a loud ticking like something hitting a fan. Any ideas?
Old 01-12-2011, 12:15 PM
Re: Unfamiliar noise...
It also was making a scraping noise like I was dragging something...
Old 01-12-2011, 01:19 PM
mopar96 mopar96 is offline
Make sure your air cleaner box is attached and locked to the bottom, check to see if clamp loosened on the throttle body also.
Old 01-12-2011, 01:34 PM
danielsatur danielsatur is offline
How about a Cat!
Old 01-12-2011, 06:31 PM
The wife was driving it and she said the temperature gauge when driving would be on the high bar but when she stopped it dropped to the cool bar. Could it be a water pump or thermostat issue? Maybe low coolant?
HA damn cats!
Old 01-12-2011, 06:39 PM
Check coolant level when cold on your coolant reservoir tank.
Old 01-13-2011, 09:29 AM
She got the gauges mixed up. I finally went out and drove it. It was the engine oil gauge, checked the dip stick and it was dangerously low. I added oil and it still sounded kind of rough. It almost sounds like it was running dry. Still not sure!!
Old 01-13-2011, 10:17 AM
Ut oh..... better drain it and put new oil in, add some lucas or slick 50 to oil. Follow slick 50 directions and run it to see what happens next.. if not slick 50 then run all snythetic. While under car chk for leaks, pull the plugs to see if soaked....
Old 01-13-2011, 02:21 PM
She could of got shorted oil on the previous oil change.
Always check oil after an Express oil change.
Try to figuar out, how much oil was missing from the previous change.
Mileage per quart of oil.
Old 01-13-2011, 08:41 PM
The oil change was done some time ago, synthetic oil. I did check it after it got done. It sounds like almost a grinding noise like something has been sitting a while and needs to loosen up. Very hard to explain. Also sounds like an air hose is loose.
Old 01-14-2011, 08:26 AM
Took it to the garage, turns out it's my A/C Compressor...
Front end noise Bob Moore Dakota 5 07-25-2009 04:40 PM
limousime 1.9 TDI 1999 ventilator belt noise kmiki '97+ 0 04-20-2009 02:40 AM
90 Caprice lower engine noise? jomo3423 Caprice 4 04-18-2009 06:23 PM
1999 Ford Expedition (E.B. Edit.) -Loud Grinding / Crunching noise in first gear UnluckyDucky Expedition 0 03-13-2009 06:03 PM
2005 G5 - V6 Clicking Noise in engine donnap1957 G6 9 02-26-2009 07:44 PM
